jonpearce1994's avatar
Mar 26, 2015
Fifth Wheel Wiring Issue?
Alright, I'm hoping I can get some help here.. I recently purchased a 1983 royal coachmen camper.. I've been in the process of fixing it up. yesterday I decided to put a radio in it, it is already wired for one. So I went out and bought a cd player from walmart for a car, tested the wires in the camper, one had power the other was a ground with some speaker wires, I hooked it up and it would try to eject the cd but wouldnt turn on, it also blew the fuse, I put a bigger fuse in the cd player (stupid) and it did flicker on once, I was getting quite annoyed at this point and somehow manage to switch the ground and power wire around and it fried that cd player. So I bought another one today, hooked it up and the cd player just made a buzzing noise, wouldnt turn on.. i left it hooked up to power and after a minute it blew up in my hand.. with a crazy amount of smoke.. never blew the fuse or anything.. it looked like the previous owner had a car cd player in it.. So i'm trying to figure out what i'm doing wrong here? or if it could be a wiring issue with the camper? I've already wasted $300 and getting pretty frustrated with it... Thank you for any help!
  • There is your problem, sounds like the converter is leaking AC. Meaning it is DEAD!
  • jonpearce1994 wrote:
    what kind of reading should I get from it? Thanks
    A voltage reading that's compatible with the device you're trying to hook up to it.
  • Alright, I just had a cheap test light, white was ground and green was power. I will go buy a voltmeter! what kind of reading should I get from it? Thanks
  • RoyB's avatar
    RoyB
    Explorer II
    It could be your wiring colors... RV Trailers use BLACK for +12VDC and WHITE for -12VDC or ground.
    Automotive car radios most likely use RED for +12VDC and BLACK for -12VDC or ground.
    Which way did you hook it up in the RV...
    Roy Ken
  • Pay attention..... BUY A VOLT METER AND LEARN HOW TO USE IT! Check voltage before wasting any more money.
  • It kinda sounds like you have AC going to it.
    I agree, get a cheap volt meter and make some measurements.
  • Please do not hook up another player until you purchase a voltmeter.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 20, 2025
