j-d
Mar 18, 2018Explorer II
lholliday wrote:
Chevy Bulletin: Correction - Print and insert revised owner manual page(s) included with this bulletin.
And this is the FIX?!?!?!?
UN-Believable!!! Towable unless you want to have a wheel dragging?
I hope somebody can furnish the "Pages."
All that said, isn't Patriot a "brake in a box" like Brake Buddy? If so, I know Brake Buddy requires pumping the toad's brakes to deplete its vacuum reserve before towing. The BB "Vantage Select" has a button we have to push to give the brake pedal five pumps before it'll go into normal operation. If I were to do the bleed, get normal operation indicator, then start the toad (creating another vacuum charge), the brakes WOULD LOCK when the BB was activated.
The light I installed will tattle on something that pushes/pulls on the Brake Pedal/Brake Linkage. I don't think the stability control pulsing the brakes will move the pedal so a light can't help there.
I added a light (LED trailer stop/tail/turn lamp) to the toad braking circuit. It gets bungeed to the mirror so I can see it through the rear window of the coach. This confirms visually when BB applies the brakes AND THAT THE BRAKES RELEASE
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
