Bob_Vaughn's avatar
Bob_Vaughn
Flukely tire pressure monitor
I have the add on tire pressure monitors that screw on to the valve stems. One on my spare tire showed it was 3 lbl low on air. So I added 3 lbs of air then it showed I was 5 lbs over. I replaced the battery with a brand new one and that made no difference. It is starting to be annoying.....
  • I guess I'm different in that I expect my TPMS to be accurate. And it is. It agrees with my tire pressure gauge/s and I would be unhappy with it if it didn't. If I had the issues the OP has I would be getting in touch with the company and have them replaced if they are in fact faulty.
  • I have an expensive digital truck tire pressure monitor and my spares never see the sun shine as they are in an enclosed garage.....Both spares are brand new and the same brand.....
  • I agree that relative pressures is what is important.
    I try to get all 4 tires on my 5th wheel are the when cold and tires are not exposed to the sun.
    Then when travelling if I see a tire that is more than 5 psi different than the others I find a tire shop or pull over in a safe place and examine the suspect tire very carefully.
    On the truck I do the same for the front tires and the rear tires.
  • I never expect to get "accurate" pressure reading from tire monitors, but all I care about are "relative" pressures, i.e: changes. Most of mine read 3-4 lbs below actual pressures, but I know what they read when I set them and that becomes my baseline for checking.
  • I would leave the spare over inflated. You can adjust it if and when you need it. My pressures are different from front to back so I inflate to the higher pressure. I can deflate if I need it on the lower pressure location.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 07, 2026
