Bob_Landry's avatar
Bob_Landry
Ford - Unhitched vs Hitched Fender Height
Just got a new F250, so I have to redo my WD. I'm going to split the difference between the two heights because that's what Ford says to do, but I'm a little curious why you would not want to return the same amount of weight to the front axle.
  • I have a F250. If I bring the front back to level the rear wheels will spin easily. Just follow the manual.
  • I'm not arguing with them either. They are the engineers. I'm just curious why you wouldn't want all of the original weight transfered back to the front end for stability. Some manufacturers, like Toyota, tell you to do that..
  • Which axle on an empty pickup is carrying more than its share of the load? Which axle is better designed for carrying heavy loads? They must figure the front can lose a little without doing any harm. I tend to agree with them since I have towed lots of construction equipment trailers without any WD with no problems. I remember when we towed with sedans and the goal with four hundred pounds of tongue weight was to put one hundred pounds on each tire.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 23, 2025
