gocamping14's avatar
gocamping14
Ford Eco-Boost Towing
currently towing a 5800 lb. TT, (dry wt.) with a 2012 3.5 eco-boost. tong wt. of camper 550. est. another 4-600 additional lb.s when fulled loaded. no problems pulling, climbing hills etc. very happy. put new Michelin E rated tires on this spring.
considering a new TT 6600 lb. dry wt. 800 lb tong wt. while well within the range of the truck, wondering if anyone is towing this much with the eco-boost or a 1/2 ton. any thoughts appreciated.......steve
  • You likely won't notice much difference if the new trailer has roughly the same frontal area as the old one.
    Only 400-600lbs of stuff, though? You travel light! Bet if you weighed it all up you'd be surprised at how low your estimate is.
  • As long as you don't exceed the GVW limit of your truck and have a good weight distribution hitch, you will be good with what you are considering.
  • Yes...Tows great!Tongue weight is 880 lbs. Very stable going down the road.
  • Well Steve, the E rated tires will help with the heavier trailer. You may have 1,000 lbs of tongue weight, when loaded to camp with that new trailer. I think the truck will pull it without issue, but you will have to watch your payload. With the tongue weight, you may only have 500 lbs left for everyone/everything else in the truck.
    What does the yellow/white tire loading sticker on the door show for payload?
    I am sure there are others towing a similar size trailer with the Eco-boost 150. The newer F150s are great tow vehicles, but with the right tow package, some are better than others.
    Jerry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
