Old-Biscuit
Sep 11, 2017Explorer III
The 'white' tank connection is 'Spun Welded' into tank. High speed tool spins the fitting melting the tank material and inserts it while plastic is hot. When material cools fitting is welded into tank
The 'black' fitting is screwed into threaded section of the 'white' connection
POLY Plastic weld repair kits available
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
