mobeewan
Sep 12, 2017Explorer
Looks like the valve is not lined up straight with the fitting. What ever is screwed into the tank fitting could be cross threaded and now starting to leak. Another though is you could have caught the valve on something or road debris hit the valve and started ripping the connection loose.
If the threads are damaged I'd clean them up as best I could to get rid of any thread imperfections and use about 3 wraps of Teflon tape to make the connection again. If it still leaked I clean up the male and female threads with a toothbrush and some alcohol and reseal using clear silicone on the threads. This is one of the rare times that I would ever use silicone.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
