- jalichtyExplorerWe spent about 14 days at Jackson in June and early July this year and, between the fridge, the stove and furnace during the cool nights, we used up one 30-lb cylinder almost. When refilling, we put in 6.5 gallons of propane. This was for dry camping and we have two cylinders as well as two batteries. You didn't say whether you used the propane stove or a furnace, but if you only used it to run the fridge, you should be able to get through the whole summer without running out.
- pianotunaNomad IIIHi,
Even a 60 watt solar system would provide enough energy to operate the gas valve on an absorption fridge nearly forever.
I try to run my fridge on 120 volts as much as I can to save on propane. - ReneeGExplorer
coolmom42 wrote:
exeter_acres wrote:
a really....really long time......
I pretty much strictly boondock.....
and I can go all summer plus some with out a fill up.... and we are out almost all the time.
the limit is going to be the battery...not the gas
This.
X2 - Francesca_KnowlExplorerI don't see a rig in your profile, so don't have any idea what you might have, fridge-wise...
As noted, most RV fridges require electricity to run as well as propane, and if yours is one of those battery life will definitely be your limiting factor.
There are some fridges (mine's one) that require no electricity to run. I've never run "just the fridge", so have no idea how long a tank would last under that circumstance. I can say, though, that using fridge and stove on a two week trip recently I came home with half a tank of propane. On a late winter trip using the heater as well 16 hours a day, a single tank lasted six days. - dbblsExplorerI suspect your battery will go dead before you run out of propane.
- coolmom42Explorer II
This. - pianotunaNomad IIIHi,
How hot is it outside? How big is the Fridge? - exeter_acresExplorera really....really long time......
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
