allen8106
Dec 22, 2016Explorer
Itakethe5th2011 wrote:
I agree with you. I have been using Gas buddy last 3 years on trips all over the country. I make it a point to stay away from those big truck stops as their prices are so much higher than brand name stations a block away. I have saved up to 40 cents a gallon. I pull a 34' Fifth wheel and never had problems fueling my pickup. Plan ahead and use Google map to look at station for ease in and out. Save money!
My only issue with Gas Buddy is that it also gives you locations behind you. I don't need info on stations behind me. As such, I use an app called The Road Ahead. Now this app has an issue also, it only works when on the interstates. As a result I tend to use both apps depending on the road I'm traveling.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
