busyguy's avatar
busyguy
Fumoto valve install
I read somewhere that you can change to a Fumoto valve when your oil pan is full by applying suction to the oil filler tube and then remove the normal drain plug and replace it with the Fumoto valve.
I have a new fumoto valve and need to change my oil and would like to do it the easy way and drain the old oil into jugs I already have.
Is this really true. Hate to try it and get oil everywhere.
Thanks for your comments
Busyguy
  • I would wonder if the fumes from the crankcase, when compressed and drawn across a sparking motor, might be hazardous. Like "boom."
  • Vacuum is a tremendously powerful force. I'm glad it worked for FF but I would be concerned it could damage a gasket or seal someplace.
    I would wait until an oil change to install it.
  • That was posted by Fuzzyface with the link to it below. (First post on page 2)
    Post
    For the first oil change on my ISL, I was concerned about capturing the 7 gal or so of oil draining out of the engine (I had the Fumoto valve, but had not yet installed it). In a stroke of genius, I hooked up my shop vac to the oil filler opening, and had my wife hold it there, while I pulled out the old oil plug and installed the Fumoto valve.....Not a single drop of oil was spilled....worked like a charm (I could actually hear air bubbling up thru the drain plug opening before I screwed in the Fumoto valve).
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: May 12, 2025
