op wrote:
What I do know though is I've never met an attorney that wasn't trying every angle he or she could come up with to get more money awarded in a law suit regarding accidents. If finding out a truck and RV are over the GCWR shown by the manufacturer, it will be an angle they would pursue.
Even if they were ignorant enough to try it won't go anywhere. Biggest reason trucks aren't assigned a GCWR...just FAWR/RAWR/GVWR. Truck mfg may assign any of the above numbers they choose.
GUIDELINES FOR CALCULATING GVWR from FHWA
**"Vehicle manufacturers may determine the GVWR of a vehicle by calculating the maximum load rating of the vehicles axles, tires, brakes, frame, suspension and wheels in order to come up with a GVWR rating. Also, a manufacturer may limit the GVWR if so desired. So they could have the componentry to rate higher but choose a lower rating at their discretion for excise tax purposes.**
GCWR ?? NHTSA website some years back.
Gross combination weight rating (GCWR) is the greater of:
**(1) A value specified by the manufacturer of the power unit, if such value is displayed on the Federal Motor Vehicle Safety Standard (FMVSS) certification label required by the National Highway Traffic Safety Administration, or
(2) The sum of the gross vehicle weight ratings (GVWRs) or the gross vehicle weights (GVWs) of the power unit and the towed unit(s), or any combination thereof, that produces the highest value.**
As we know our trucks aren't assigned a GCWR so we go to (2) paragraph.
DOT considers the sum of the trucks GAWRs can safely be used as its GVW or a GVWR.
NHTSA says this about components of the GAWR:
**"Gross Axle Weight Rating is the rated load-carrying capacity of an individual axle and wheel assembly. (It represents the load that may be steadily sustained by the components in the system; i.e., tires, rims, hubs, bearing, axles, brakes, suspension, sub frame, etc. with the GAWR limited by the components with the lowest working rating".**
Coming from the commercial side using mostly one ton DRW trucks and heavy GN trailers we don't get sued or ticketed by exceeding the truck makers GVWR..... and of course a GCWR as its not on the trucks certification placard so no ticketds or lawsuits there either. WE can be sued/ticketed by exceeding a declared GCW or the vehicles steer/drive or trailer axle/tire load ratings.
I doubt the same size truck pulling the same weight rv trailer is any different.
A GCWR can be changed by a simple gear change. Or tranny change. Or a engine change. Or the same engine with a 2 barrel carb had a different GCWR than the same engine with a 4 barrel carb. And with some older trucks even a wheel/tire size would affect a mfg GCWR.
The truck mfg tow rating is a good number to shoot for however I sure wouldn't exceed the GAWRs....mainly the RAWR as its carrying most if not all of a trailer hitch load and other gear in the bed.
