Dick_B's avatar
Dick_B
gas line interferes with drain plug
I have a new Dometic Water heater model G6A-8E-SP,gas only with spark ignition. The gas line into the Heater is much inline with the socket needed to install/remove the drain plug. I can still do it with a channel locks but it is more difficult and will eventually round off the hex head.
Anyone had this problem and solved it?
I don't know how to add a photo.
I found something, not previously mentioned, that worked for me yesterday. It is CTA Tools, 2573, Low Profile 24 mm socket that was originally designed to remove oil filters, I think, but worked for me tightening up the drain plug once started by hand. It uses a 3/8 inch drive.
  • I took my plug out completely and installed a 90 degree drain valve with a hose that is routed under the RV to drain.
  • Yes the drain plug is right behind the gas line/gas valve
    A socket can not be used unless you remove gas valve
    Use a combination open/box end wrench over the top of gas valve
    7/8" or 15/16" depending on plug vendor
    Loosen with wrench then remove with fingers
    Install finger tight then snug up with wrench
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 22, 2025
