acritzer
Apr 15, 2015Explorer II
VintageRacer wrote:
The manufacturer of the vehicle or trailers maximum recommended pressure. The vehicle is on the door jamb sticker usually, often the trailer is on the data sticker with the VIN. In the absence of that information, the maximum pressure on the sidewall of the tire.
Brian
I understand that. Maybe I didn't ask clearly enough.
-Is it "generally" OK to run slightly under max pressure?
-If you're loaded light you should run "this much under max"
Etc. Simple guidelines that are good rules to follow.
I read a blurb somewhere that suggested not to inflate to max.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
