acritzer
Apr 15, 2015Explorer II
goducks10 wrote:
You don't need to run the max if you're not towing the max. If you are only putting 600lbs on the rear of a 3/4 ton then 80 psi isn't necessary. If you're maxing out a 1/2 ton then yes air up to the tires max sidewall psi. I would go as far as to say always run max psi in a 1/2 ton when towing because most are near the upper end when hitched and loaded.
What are you towing and what's the load in the truck?
Towing a Keystone Cougar 29 BHS with an Expedition EL. Load in the truck 2 adults approx 315lbs. 3girls 1 boy- ages 10, 7, 4, 1....not sure on their weight! Minimal equipment.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
