BenK
Apr 15, 2015Explorer
Tire PSI is more to hole the tires shape than just holding up weight
Just 15PSI or so for most tires will 'LIFT' the vehicle corner's wheel
off the ground.
Higher than that is to maintain the tires shape for its duties. Stopping,
accelerating, directional control, shock absorber, etc, etc
Might be helpful showing what can happen to over inflated and under inflated
Did a quick search and posting several examples for others to also
see/learn about this, as this question is a constant
X2 on mower's chalk test. Add that some use masking tape. I always
check when there is a transition from wet to dry pavement and look
at the tread contact patch on dry
tireinflation
tireinflation tirecontact contactpatch
tireinflation triecontact contactpatch
underinflation tireunderinflation underinflationfailure
tireinflation overinflation underinflation
off the ground.
tireinflation
tireinflation overinflation underinflationAbout RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
