Sport45
Apr 15, 2015Explorer II
mowermech wrote:
There is, of course, the old-fashioned "chalk test".
Go to a large parking lot, make a chalk mark across the tread of the tire. Drive a few feet, then look at the mark.
If it is worn off mostly in the center, the tire is over-inflated.
If it is worn off mostly at the edges, the tire is under-inflated.
If the mark is evenly worn, the inflation is just right.
Same principle, but I use masking tape across the tread instead of chalk. I'll check it after driving a few miles and adjust the pressure until the wear pattern is slightly biased to the middle.
I kep trailer tires at maximum sidewall inflation pressure to minimize heat. In my experience, trailer tires are always replaced before the tread wears out anyway.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
