sato4000's avatar
sato4000
Generator can only run AC with everything else off
I've have a durostar 4400 peak 3500 watt generator. It runs everything but the AC fine without any issues. To power the AC however I have to turn all of the other breakers off except for the main and the AC otherwise the breaker on the generator will flip. Is this normal? The AC is a roof mounted dometic in a coachmen freedom express toy hauler. Does this mean with everything off except for the AC the AC is pulling close to 3500 watts continious? When i got the trailer brand new I had issues with the water pump. Come to find out they had wired it backwards at the factory and burned out the motor. I'm not an electrician but just wondering if something else could be wired wrong or something to have it drain that much power.
Looking for advice before your next adventure? Look no further.25,131 PostsLatest Activity: May 12, 2025
