Mike_Up's avatar
Mike_Up
Getting Rid of my Dual Cam system
I really like this system but it's such a darn pain. It's so complex no one, anywhere, has any idea how to adjust it or install it.
I just had it transferred to a new trailer and new bars also werer needed. Backed it up at home to get it in the driveway and bam, broke out the top socket of the head. I've been told here that it was installed/adjusted incorrectly and I believe that.
And now, the dealership is arguing that it was installed correctly. After talking further to them, the dealer doesn't have a clue and I can't believe they got it installed as far as they did.
I really like my Strait Line system but it's just to complex and I'm done with it.
I'm looking at going with either a EQUAL-I-ZER brand or Blue Ox brand. To be honest I really like how easy and simplistic the Blue Ox brand is. What I don't like are the very VERY vague installation instructions and their short 3 year warranty. This is the system my Dealership pushes.
It's not that the Equalizer brand is bad, I just don't like how you have to tear the head apart to get to the washer adjustments and tear down the brackets to adjust them. This system looks nearly as confusing as the Reese Strait Line (HP Dual Cam and WDH).
So is the Blue Ox inferior to the Equalizer Brand or do they both work well???
Here's a big point to me, since I have to back up at extreme angles, how do they do this. I called both makers and they said they hitches wouldn't hit the ball threads/nut when turning but what's your experience.
The Reese Strait Line system has so many binding points it's nuts. I think mine bind on the cam installation bracket, broke the top socket out of the head, the T end of the Trunnion twisted while forcing it's way out of the head, and hit the ball threads. All of this because the dealer refused to adjust the head to a greater angle to get the bars below the cam brackets. They are sticking to their guns saying you can't adjusted the head beyond the threads on the adjustment area, therefore limiting how far back they could tilt the head. They only got 5 chain links from the bar's end to the snap up bracket with a 1200 lbs bar.
So now I'm going to shell out money and hope to install this thing in a timely manner, myself, on an uneven, slanting driveway because no one in my area knows how to install a hitch unless it's a simple WDH with no sway control.
Can you believe the guys at the dealer even said it was my fault for breaking my head because I didn't take out my WDH bars before backing up. :E :E :M Guess I'm suppose to put 900 lbs on a hitch receiver that states only 500 lbs when no WDH is used?!! :M
So Guys can you help me, Equalizer brand or Blue Ox. BTW, both are about the same amount of money and both claim 4 point sway control.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 14, 2026
