rwbradley
Sep 29, 2015Explorer
BamaVan wrote:
Is there a way to just just bypass the regulator on the Baby Q? I want to be able to use it both hooked up using the trailers regulator and at home with the Q regulator.
See the instructions I posted at the beginning of this thread. You can do the mod to run off the trailer. The beauty of this is that the quick release makes it very easy to plug things in. This solution will give you the male quick release permanently installed on the Weber, but you can put a female quick release on anything you want not just the hose to the RV. If you put a female quick release on the old regulator, you can also get the Weber hose to hook up to a 20# tank and use it with the original regulator. It just takes a quick snap to plugin or unplug whichever setup you want.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
