rwbradley
Oct 06, 2015Explorer
bbaker2001 wrote:
I wish there was more heat coming out so I could grill or make pancakes with top open.
is it possible to drill out the hole sizes to increase heat?
I put foil on bottom and then throw it away. I wish someone would make a fitted piece to go in the bottom
I suspect that drilling the holes out would be quite dangerous. I believe the number of holes and size of the holes are designed to exactly offset the pressure of the gas coming from the regulator. Tinkering with that may cause the gas pressure to be too low and there may be a risk that flame could flow back down the hose, which would be really really bad :(
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
