I agree with all that Ben has said and will just expand on the following:
BenK wrote:
The amount of forces +/- is factored by the number of chain links, or more accurately how much the chain will allow the bar end to move or not move. The bar's preload will either increase or reduce...but am having problems with that, so see last sentence
I'll let you guys hypothesize the pound forces, both push and pull on
the tongue in reference to the center line
The following chart shows how bar-tip force varies as a function of TV/TT articulation.
The chart assumes each trunnion axis is offset 4" from the ball center and the A-frame included angle is 50 degrees.
Each trunnion axis is tilted at 15 degrees in a vertical plane which is parallel to the TV's longitudinal centerline.
Each bar is loaded to 1000# at zero articulation (TV and TT aligned straight ahead).
Next we need to consider how much the right bar tip moves "forward" relative to its chain suspension point and how much the left tip mores "rearward" when the TT swings left.
Assuming a 4" offset for each bar trunnion, 25-degree angle between A-frame and TT centerline, and 30" from ball center to chain suspension point --
if the TT swings 5 degrees left, the right bar tip will move forward a theoretical 0.337" and the left will move rearward 0.327".
If we assume the distance between bar tip and chain suspension point is 4" (about what it looks like in the Blue Ox videos),
each chain will be at an angle of about 5 degrees from its original assumed vertical orientation.
The load on the right bar has increased to 1025# and it will be pulling forward with a force of 86# on the right chain latch.
The load on the left bar has decreased to 968# and it will be pulling rearward with a force of 79# on the left chain latch.
So, the forces due to the inclined lift chains will tend to return the TT to zero articulation.
HOWEVER, if the WD bar trunnions were at
zero tilt and assuming the same distance from bar tip to chain suspension point, the restoring force would be almost identical to (actually slightly greater than) the restoring force resulting from the tilted trunnions.
And, the difference in favor of the non-tilted trunnions will increase as the articulation increases.
So, if there is truth in the assertion that tilted trunnions will provide a measure of sway control which cannot be provided by zero-tilt trunnions, I think we have not yet found the reason.
Ron
