gmw photos wrote:
BarneyS wrote:
I fail to see how the chains can supply much,if any, sway control at all since the brackets pivot right along with the a frame and bars in a sway event and in a turn. The bars DO move forward and back but are not rigid side to side, which would be necessary for sway control to take place.
Barney
When the trailer is not in line with the tow vehicle, the bars have an unequal force applied to them. That unequal force is applied ( if I am understanding it correctly ) because of the fact the head of the hitch is tilted backwards at it's top.
As proof of this, when I am cranking up the chains on this hitch, if I don't have the truck exactly straight in line with the trailer, one bar will "chain up easily" while the other bar is very difficult to get the latch to turn. In that case, I have to crank up the tongue jack some more to get enough weight "off the bars".
It's that unequal force, created by the geometry of the hitch head, bars, and attaching chains that is apparently the force the keeps the trailer inline when it tries to sway.
At least that's my take on it. All I know is it works. And the weight distributing part works as well, a fact I verified by setting mine up and going to the CAT scale.
Hi Barney,
I have seen the new version up close at dealer and took a bunch of pics. The hitch is made well, craftsmanship wise. And it does have grease fittings on the trunnion pivot pins. There are no trunnion pivot bolts to tighten. The trunnion sockets pivot free other than the high force of the WD pulling on them.
Blue Ox has now created a video with a computer simulation. They show a computer model creating the effect gmw photos is explaining.
This
Blue Ox should fire off Blue Ox site and scroll down to the 6 minute info video. They do not come out and say it, but they are down playing the Reese. I can tell they are Reese parts.
The WD part is straight forward like any other conventional WD hitch. However as said, no more head tilt. So chain links is the total adjustment. If you get real heavy bars in relation to the TW, the chains are going to hang down pretty far which then comes to the anti sway part.
The profile of the WD bars leads itself to be able flex more easy as compared to say, an all square Equal_I_zer. The concept "appears" to be counting on an angle being created down the center line of the truck and TT at the tow ball to create higher force on the down stream WD bar in relation to the sway force acting on the TV and TT. That higher force would tend to want to push the connection back towards the direction of sway force.
They intentionally have a large tilt angle backward on the hitch head to help create this higher force in the WD bar.
I can see the force it creates reacting on the hitch head and wanting to help bring the TT back in line. The further off center the TT and TV go, the larger the force. A similar WD force occurs on the Reese DC if the hitch head is titled approx 7 to 10 degrees to the rear. On the Reese the down stream WD bar increases in WD force riding up the cam and increasing the ultra high friction.
A difference in the Blue Ox is that the TV and TT has to become out of line for the force to build as going dead straight ahead both WD bars are loaded equal.
An unknown right now is, for a given TT length and TV wheel base how much force is needed in that down stream WD bar and how much off center angle of the TV & TT to exert enough force at the hitch head to dampen the sway action? Good question.
The ultra high friction hitches like Equal-I-zer or Reese DC use the friction to help prevent the angle between the TT and TV from forming while the Blue ox needs some level of angle for it to work.
I can see the force happening they are talking about, I just can't yet sort out how much force is needed and how far the angle between TV and TT needs to get to be effective in anti sway control of a large TT.
This would be a good one to stimulate Ron Gratz with.
John
