rhetthughes's avatar
rhetthughes
Good glue to withstand heat and weight?
Hello everyone! I’m having an issue where the front panel of my dometic fridge keeps sliding down. It’s no harm to anything other than one extra layer of insulation. I tried some heavy duty double sided tape that is supposed to hold 20 lbs per whatever small square strip of it. Didn’t work. Figured the 5 pieces I used was not enough so doubled the amount. Just picked up my rv from storage and it had slid again (this was after several camping trips with additional tape. So I’m guessing I need to find some kind of glue that will withstand summer heat in South Carolina and apply a generous amount to the back and to the sides where the panel inserts into the plastic side frames of the door of the fridge. Any suggestions on a glue that will work to hold that front panel in place? Thanks!
  • shoe goo
    I used it to hold a D.C. Circuit breaker mounted to a 2000w inverter
    And that case gets pretty warm
    You will need to tape?
    The panels In place until the goo sets 12>24 hours for full cure
  • I have had really good luck with Goop everything that I used it on has stayed in place.
  • I do not know the exact specifics of your situation, but would contact cement work?
  • 2DHoop wrote:
    Hello, will you need to be able to remove this panel at any point in the future?
    I can’t imagine ever needing to. It’s just reall decorative - that black panel on the standard camper fridge.
  • Hello, will you need to be able to remove this panel at any point in the future?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
