RDMueller's avatar
RDMueller
Good w/d hitch choice for improving the ride in the TV
I'm looking for opinions from those who have towed with different hitches regarding which ones performed the best in terms of the ride.
My setup:
TV is a 2001 Ram 2500 diesel quad cab long bed
TT is a 2015 FR Wildwood 28DBUD (29 footer with a GVWR of 7805)
I initially towed with just a weight carrying hitch and a friction sway bar. In this configuration the truck stayed level and the steer axle still had 3400 lbs on it, a reduction of less than 200 lbs. Tongue weight was about 900. There was no sway and handling was fine. On smooth roads, it towed great, no issue whatsoever.
The problem was simply ride quality on poor roads. Driving over a bump or dip in the road would cause a front to back rocking motion that was pretty uncomfortable at times. So began my quest to improve the ride. Here's what I've done so far:
1. Replaced the aging shocks on my truck with Bilstein HD shocks. This produced a modest improvement, but the front to back rocking was still present, just not quite as severe.
2. Upgraded my hitch to an Andersen no sway no bounce w/d hitch. I did a lot of research here and elsewhere before deciding on this hitch. It seemed that "bounce" was probably the best word to describe the front to back rocking I was experiencing and this hitch was supposed to address that. Some did say the Andersen has a hard time restoring enough weight to the steer axle with heavier tongue weights, but because of the very long wheelbase of my truck, that was not really the issue. Anyway, I will say the Andersen made a substantial improvement. However on the worst highways and interstates, the front to back rocking when hitting a bump or dip is still very much present and can be quite annoying.
3. Upgraded the trailer suspension to the Dexter E-Z Flex suspension. I'm sure this made a huge improvement inside the trailer itself, but it didn't make that much of a difference in ride quality in the truck.
At this point, I don't know - maybe this is just as good as it gets. After all, it tows really well on good roads. But we all know, the condition of our highways and interstates in this country is often not great. It is what it is. But I do find myself wondering if there would be a better hitch option that would smooth things out some more.
It does seem to be almost universally accepted here that a Hensley or PP is the best hitch you can buy. However the issue that seems to be front and center when talking about a Hensley or PP is sway and how their design prevents sway from ever beginning. I have no issues with sway whatsoever. I'd be happy to invest in a Hensley or PP if it would substantially improve the ride. But I'd really hate to spend that kind of money only to get little or no improvement over what I'm seeing with the Andersen.
I know a lot of people swear by their Equal-i-zer, Reese dual cam, or Blue Ox sway pro. Judging by what I see walking thru campgrounds, those make up the vast majority of the w/d hitches. I almost never see another Andersen and not very many Hensley or PP hitches. Since the first 3 don't represent a huge investment, I could just try one and see if I like it better than the Andersen. But before I do anything, I'd love to hear from people here who have likely gone down this same path.
As usual, thank you in advance for the good advice I know I will receive!
  • Airstreamer67 wrote:
    The truck-and-trailer combination makes for a 50-foot-plus articulated snake that is prone to moving like a sine-wave on undulating surfaces such as disjointed Interstate concrete slabs.
    I don't think there is much that can be done about it, except perhaps drive on different types of roads, such as smooth blacktops that don't have expansion joints every few feet.
    I've been using an AirSafe hitch for 10 years now. It is a wonderful hitch that does provide all the many benefits they claim. However, when it comes to some of the concrete slabs I drive over, it's roller-coaster time, folks.
    I agree, especially on the airsafe hitch. It does wonders, but as they say "you can't defy physics". It helps decouple the TV from the trailer but it can not decouple completely.
    Thankfully, even on a bad road it turns a terrible awful road into just a not nice road. I've driven over some road before and after I installed the air safe hitch and it did and does make a big noticeable improvement.
    but given it's cost and weight it is not really a good solution for everyone.
  • I can almost guarantee that a stiffer set of shocks will cure the problem. Those Bilstein HD 4600's are a very soft shock, not made for controlling heavey loads. Get some adjustable ranchos and set them up stiff. It will be night and day difference.
  • Dump the Anderson and go with a Reese DC, EQ, or another type of traditional hitch, with the proper weight bars for your trailers loaded, ready to travel weight.
  • Thanks everyone for all the advice and ideas! There are clearly a number of things I can do, each of which will probably provide incremental improvements. I agree that the first thing will be to try a different hitch. Of all the things I've done so far, going from no w/d to the Andersen was by far the biggest improvement. A hitch that can restore 100% to the front axle may be all it takes to make me happy.
    If after that I'm still looking for improvement, stiffer shocks for the truck or timbrens would be a fairly easy and low cost thing to try. Last would probably be the Air Safe. It looks like a beautiful product and one that looks like it's designed to deal with precisely what I'm complaining about. But considering the cost, I'll definitely be trying the other things first!
    I'll definitely update this thread after I try a new hitch.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
