importman's avatar
importman
Got a question for the group please...
Hello all, After looking and debating for a while my wife and I have secured a permanent site at Hide Away Campground in Bryson City NC. At 60 years old and with arthritis and bad back trouble it was just getting to be too much trouble setting up and tearing down. So with that we're going to try to make our travel trailer as comfortable as possible considering we will likely be staying in it for longer periods of time especially during the Summer. I've ordered two lazy boy recliners as the first step towards that goal. And I've decided I need to mount the tv to the wall on one of those single arm mounts so I can swing it toward the sitting area or the bed depending on where we want to watch. That leads to my question. My camper has the aluminum frame fiberglass laminated walls. I call them composite but I'm not sure if that's correct. From previous experience I know that getting something to attach to them is about as successful as hanging something directly to sheetrock without anchors. So what I plan to do is attach a piece of 3/4 plywood to the wall; I'll probably bevel the edges and stain it to make it look okay. Then I can attach the mount to the plywood and it should be fine. The question is, how to attach the plywood to the wall or better yet, how do I find an aluminum stud in one of these sandwiched walls? I saw an app called wallabot for android that looks like it would work but unfortunately I don't have an android device. Can anyone tell me how I can find the aluminum studs in my wall? Or does anyone have any good ideas on how to attach the tv mount to the wall? Thanks in advance for any help.
  • Or you can simply push on the luan paneling you can feel where the studs are.
  • What ScottG said . . . Plus , I think standard stud finders may also alert on aluminum studs....you might try that.
  • Wait until there's a morning with heavy dew and all the framework will be revealed on the outside of the trailer.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
