TNRIVERSIDE's avatar
TNRIVERSIDE
grease on TT brakes. what will happen?
I pulled my TT brake durms to inspect and repack the bearings. I was surprised to find a small amount of grease on the outside of the seal. Fortutaly there was no grease on the drum or business side of the shoes. With only 5,000 miles I did not expect to see a seal failure. I did NOT add grease using the grease fitting on the axle. So hear the question.
If I had added grease to the bearings using the fitting on the axle with the failed seal what would be the outcome other than grease on the shoes and an expensive repair bill?
Would there be only brake failure?
Possible fire?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
