Artum_Snowbird
Apr 17, 2015Explorer
I think I would get some tape and put it over all the areas you can put it, then do the spray test again.
If it doesn't leak, remove one piece of tape and try again..
If it does leak you have to look elsewhere... perhaps at the hinge itself. You can remove the little screw at each end and slide the door right out of the hinge for inspection.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
