MFL
Mar 09, 2017Nomad II
GCWR is mostly a drive train rating. This means that if you tow over this manufacturers rating, you will cause stress to your drive train, causing it to wear, or wear out at a faster rate. This number will go up with HD tow packages, such as larger radiator and fan, more transmission cooling, and lower differential gearing. It is more of an excessive wear number, than a safety number.
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
