JIMNLIN
Jan 18, 2015Explorer III
LarryJM wrote:AH64ID wrote:
1/2" on standard axle spacing is about 1.5% difference, while it's noticeable its not the end of the world.
Chances are if upgrading from 15" to 16" the 15's were OEM and will support the axle rating. The 16" combo should support more than the 15" combo and everything will be fine.
There are some more torsion axle TT's but they are still not very common.
I guess we can all guess at what the real effects are, but IMO I think the issues are greater than they might appear at first glance. Just as those that don't think there are problems can't cite specific facts to support their view I really can't either except by extension in the caution about towing a torsion trailer level, replacing both tires on the same side when only one has failed, and the very slight difference in diameter on duals of only 1/4" as cited HERE, not to mention the caution from almost all reputable sources to not mix tire sizes on tandem axle trailers. Finally, as I stated originally using a car as a similar situation is not appropriate.
I think the risks are simply not worth the couple of hundred $$$ in short term savings when you could be risking Thousands of $$ in damage from a catastrophic tire failure.
I seldom see mentioned or people actually saying they replace both tires when only one has failed on a tandem axle trailer, but I for one have followed that practice and will continue to do so.
Larry
Speaking from actual experience of using tires with up to 2 1/2" different diameter tires as a spare on several different size equipment trailers over many years and over 800k+ miles of continues service in my business, I found my trailers had no short term or long term damage from using them temporarily the ground (several hundred miles) as a spare.
The biggest issue I found was braking issues between the two different diameter tires because of the different wheel speeds.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
