Our_Place's avatar
Our_Place
Heads up if you use Aqua-Kem "toss-ins"
I changed to these early this year and thought they was the cat's *** but it turns out they are trouble! I have discovered that the "plastic bag" that is suppose to dissolve in water is not doing so and they are just dumping out with the solids. I had one snag on the inside of the dump hose and that is how I found out they don't work, it still had the blue powder inside it as a clump of blue paste. So today at work I took one and tossed it into a 5 gallon bucket half full of water and at the end of the day it was still floating on top, not dissolving at all! Watch out for these...........
  • robsouth wrote:
    Why do you need any of them? I just use the geo method and never have a problem with odors or otherwise. Many folk just use plain water and have good results.
    Nothing wrong with that method. I had septoplasti for sinus problems. My smell system now seems very accute. I use them because my MH smells terrible not using anything. I even use the grey water treatments. If you don't smell it not a problem.
  • Thanks for testing and posting your results.
    I thnk we had a similar experience with one coming out intact during dumping. (Really like those clear elbows for the dump hose.)
  • Why do you need any of them? I just use the geo method and never have a problem with odors or otherwise. Many folk just use plain water and have good results.
  • I use a brand called Porta Pak. Just tested it in a mason jar. Less than 5 mins it was dissolved, and no trace of the plastic bag.
    Mike
  • I start them in a bucket with half a gallon of really warm water. It takes about one minute for it to dissolve before adding to the tank. Then I use that bucket to add about five gallons of cold water (and rinse the bucket).
  • Lots of posts on this subject. You really need to educate yourself on how dangerous these things are. Not only to your plumbing system, but to the enviroment.
  • I had wondered about that. Thanks for the heads up. I tried the dry packets you pour in to the tanks too. The dust /fumes from the powder got in my nose. I probably didn't do it correctly but they are off my list, too. I'll just stick to the liquid.
  • I use TST toss ins. I never found them totally intact but but noticed the outer pouch gets slimy and sticky if it gets wet. I have also noticed partial pieces of the outer bag stuck in the sewer hose when disconnecting. I like the convenience so I keep a pair of shears in the bathroom. I cut the bag and dump contents into the toilet. I put the bag in the trash. I suspected it was a problem but this is the first post I have seen about it. Good info.
