DtaylorExplorerApr 24, 2016Heat IssueOur last trip out our heat failed to work. The fan would come on but it sounds like the gas is not igniting. The fan runs for a period and shuts off. I pulled the access panel and I can see a light fl...Show More
Old-BiscuitExplorer IIIApr 25, 2016Atwood Furnace Error Codes Fault LED IndicationInternal Circuit Board fault Steady on, no flashingLimit switch/Airflow problems 1 flash with 3-second pause Flame Sense fault 2 flashes with 3-second pauseIgnition Lockout Fault 3 flashes with 3-second pauseWhat error code do you have?
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
Related ContentOutdoor Griddle Heat Issue12 Volt Power IssueElectrical outlet issuesOver heating issueDometic 2-Way fridge repair issues
