valhalla360
Mar 12, 2021Navigator
Higher hitch weight is almost always better.
Where people get in trouble is they try to take a light duty (low payload) 1/2 ton and then get caught between keeping within the payload but above 10% hitch weight.
With a 3/4 ton, it should be able to handle a 1200lb hitch weight no problem.
5th wheels are some of the nicest towing trailers and run 20-25% hitch weight with no fancy hitches. Semi's are commonly at 50% or higher.
Unless you are having sway or other handling issues, run with it.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
