JBarca
Mar 13, 2021Nomad II
Andrewmart wrote:
I haven't had any swaying problems with it but yesterday I was towing and getting pushed all around. Weather app said wind gusts were up to 25mph. I think more... My wife was in her expedition and also getting pushed around. It's the most I've felt the RV since I got the F250. I know there is nothing I could do to stop the crazy wind hitting our 33 foot long wind sail, but wondered if me being too hitch heavy contributed. Google says too heavy hitch can cause TV steering problems. It wasn't necessity swaying, it was more getting pushed around out there with each gust. In between gusts or when highway changed to head wind, I had no problems.
Hi, I'll add some not yet mentioned.
As was said, you do not need to change the tongue weight because it is over 15%. I run 16% on mine all the time, on purpose, and the last camper was 18 to 20% pending fresh water. But the truck, WD hitch, truck receiver, and camper A frame have to be able to handle it. In your case, as long as the WD hitch WD bars are sized right, the F250 not overloaded on the rear axle with extra stuff in the truck bed, your truck receiver is at or under the ratings, then those areas are in check. The camper A frame, that will be a separate topic.
A too light of a truck front end can affect handling, which is part of what the Google too heavy a hitch was talking about, but that most likely was not put it in the right context. There is more to what heavy means and what light means. Too light a front end can happen due to the WD is not set right regardless of TW. I run my F350 lighter on the front end on purpose, but not excessively too light.
To your being pushed "all around" in winds, the Pro-Pride or the Hensley are very good hitches. But any, WD hitch has limitations and they will not solve a truck tire issue on long TT's. Something not talked about yet is the truck.
What year truck and if a new truck or old truck with new tires, please give us some info on these questions.
1. What was the air pressure in the front and rear tires while towing?
2. What does the driver door sticker state is front and rear tire pressures?
3. How many miles on the tires since new?
4. What size , load range and brand are the tires?
5. Are the tires OEM sized to the truck, or do you have an aftermarket up grade/larger size on tires?
6. Does the truck have an aftermarket lift kit on it?
7. Not tire related, but truck related for left to right stability. Does your F250 have overload springs (helper springs) in the rear? A 2 stage spring set up. Or does the truck have a roll bar on the rear axle? If it has the overload springs, was the rear most overload spring kissing the truck frame bracket when you are hitched for towing? Some F250's have the rear overload spring setup, some don't.
The WD hitch will not correct for tire stiffness or a tire break in period of new tire with the newer rubber compounds. Handling issues can and have happened on 3/4 and 1 ton truck all linked to tires issues. You need to check the box that the tires are not part of the problem.
Hope this helps.
John
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
