Gene_K_2
Mar 16, 2021Explorer
Andrewmart wrote:
I have a 2020 SPORTSMEN® SE 301BHKSE that I tow w/ a 2015 F250 gas engine. I use a Propride 3P hitch. I went to the Cat scales today and found a hitch weight of 1220 lbs (did all 3 weight measurements). TT is 7000 lbs, so that puts me at 17.4%. I can provide the data if needed.
Should I consider changing to a lighter WDH to reduce tongue weight and get closer to 15%? Or is being over 2-3% not a big deal? Does being over weight w/ a 3P sort of offset the overage?
Considering changing because, while I love the 3P, hooking up is a chore. We've had the 3P for about 8 months and taken about 10-12 trips with it, and I still struggle with hooking up. Before the 3P we had an equalizer and I attached to the ball easily.
I only towed with the equalizer twice (on a 1/2 ton vehicle), so not sure how much of a difference switching WDH will affect the driving. We got the 3P because we had a 1/2 ton vehicle, but we ended up upgrading to the F250 after one trip. Had we gotten the F250 from the start, I doubt we would have even gotten the 3P.
Since tongue weight is measured at the trailer tongue how would changing your WDH effect it?
You need to subtract the weight of the WDH to get your actual tongue weight.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
