BackOfThePack
Apr 27, 2021Explorer
Longest life (best performance in braking & handling) WILL be with correct tire pressure.
Not otherwise.
The RV world is full of those who think screwing around with tire pressure is how to fix a problem. Tire pressure is ONLY related to its load. (Use a CAT scale; tire manufacturers load & pressure table and INSIDE vehicle manufacturers RANGE). Get it dead-nuts then test.
I run my ‘04 CTD at 50-psi all around. (As above). Took two sets of tires to cover 250k (MICHELIN).
Still don’t like handling/steering then the WDH needs verification (Three Pass Scale Method).
Better shocks (replace at 40-60k with KONI or BILSTEIN). R&R anti-roll bar bushings with poly inserts.
SUPER STEER Rear Trac Bar (3/4-1T) cures tail wagging. Most (almost all) pickup owners don’t get it that THE TRUCK causes loss of control accidents at a higher rate than do the trailers attached.
Keeping PROPERLY inflated rear tires on the ground is the whole game.
Tires TOO HARD are NOT a good idea. Pressure is a “fixed” value.
Not otherwise.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
