familyman5's avatar
familyman5
Help, Ford Explore battery dies when flat towing
I have a 2014 Ford Explorer that is supposed to be able to Flat tow without pulling any fuses but the battery dies and less than four hours. I purchased this vehicle to tow behind our motorhome because it is supposed to be able to go six hours before needing to run the car engine for five minutes to recharge the battery. I just towed the vehicle on our first trip and after four hours the battery was completely dead. I followed the owners manual that said to put the key in the accessory position. Note that I am not using a braking system that requires any battery power and I had the battery checked at an auto parts store and it was fine. Can anyone help with this?
  • It indeed could be difficult. I've read 2 vehicle threads (Honda and GMC?) where the vehicle could not be towed contrary to the manual. Both owners were offered signifcant compensation/replacement after extended persistence by the owner. They were under warranty which helped them make their case.
    If you bought from a dealer then be persistent with their help. Remind them that you can read the manual as well as them and that is not answering the issues.
