Baja_Man
Dec 26, 2017Explorer
Am I trying to get as close to the 3740# truck front axle weight (unloaded, truck only)?
Is 50% back the number between 3700# and 3220#?
If so, then I need to be at or above 3460#, correct?
Equalizer manual states to ADD washers to increase weight distribution.
Anyone know approximately how much weight can be expected per washer?
Should I add 1 or 2 washers?
I'm inclined to add 2 to get as close to the 3700# as possible? Is too close back to unloaded front axle weight a negative?
Moderator note: Sorry about the edit. I hit edit instead of Quote.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
