Ron_Gratz
Feb 14, 2016Explorer
LarryJM wrote:Larry, here's what's going to happen if you put someone on the rear bumper and make a second run across the scales:
NO the fact is your view is just YOUR OPINION which is NOT SHARED by many others including those who produce hardware. The purpose of a WDH is to redistribute the weight (called "TONGUE WEIGHT") that is put on the ball of the hitch and once you hook up the WDH system adding cargo aft of the TV rear axle will increase that value and show up as weights applied to the axles of both the trailer and the TV. Hook up your trailer run across the scales and then have someone stand on your rear bumper and do a second run across the scales and all your weights including those on the TT axles will change. That can only happen if the "TONGUE WEIGHT" has changed unless you have adjusted your WDH system.
In the end as I said in that link there are two "camps" on this and your are in one and I'm in the other, you're not probably going to change unless you're willing to learn and listen rationally and I'm not going to change unless my CAT scale example above was proven to not be correct and all that weight from that person on the rear bumper only showed up on the TV axles only.
The weight of the second person (let's assume 200#) will cause the front of the TV to rise and the rear of the TV (and the ball) to drop.
The drop of the ball changes the vertical angle between TV and TT and causes the WD bars to pull down harder on the A-frame.
The increased downward force on the A-frame will cause increased downward force on the TT's tires.
Consistent with Newton's third law, the pavement then will exert an increased upward force on the tires.
Let's say this increased upward force is 50#.
Let's also say that prior to adding the 200# person to the TV's bumper, the TT was exerting a downward force of 800# on the WDH.
Since the pavement now is exerting an added upward force of 50# on the TT (without changing the mass of the TT), the previous downward force of 800# acting on the WDH will be reduced by 50# leaving a downward force of 750# acting on the WDH.
Increasing the load on the WD bars always reduces the magnitude of vertical downward load acting on the hitch head.
Otherwise, the WDH could not cause load to be removed from the TV's rear axle and added to the front.
You are correct that adding load behind the TV's rear axle, with WD engaged, will cause load to be transferred to the TT's axles.
However, transferring load to the TT's axles does not cause the vertical load on the hitch/receiver to be increased.
Quite the opposite -- it causes the vertical load on the hitch/receiver to be decreased.
Ron
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
