lbrjet
Feb 15, 2016Explorer
The correct info is anything in the truck should not be considered tongue weight and none of that weight needs to be shifted by the WDH. It can be by cranking up the WDH to tight, but shouldn't be if set up correctly. That is why you start taking measurements after the truck is loaded for travel. That is your baseline. It really is that simple.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
