lbrjet
Feb 15, 2016Explorer
Larry, your experts simply want to sell you a larger more costly hitch. It is called marketing.
You run your van with weight behind the axle without the trailer hooked up. What you fail to see (or will not admit to see) is that hooking up the trailer ( without shifting that aft weight) is no different than running without the trailer hooked up. That is the whole point. A truck is designed to run with a load in the bed and dropping a trailer on doesn't change that.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
