valhalla360
Aug 06, 2023Navigator
With a toy hauler, probably a no brainer.
One item to check into (probably won't change the outcome) but the running wattage (amp * volts) by itself doesn't tell you which is more efficient.
- I suspect at least for the 120v AC unit, they are providing the max amps. I doubt it's pulling 720w while running.
- The other big question is what percentage of the day the compressor is running. The higher wattage unit may be more efficient if it runs less time each day
- On a related note, how well insulated are the units. This can heavily impact how much the compressor runs each day.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
