1. We travel with 1 propane tank always filled
2.water tank is up front but tend to not travel with water.
3. It appears that front axle, wdh engaged is putting all of the weight back to front axle. Manual suggests approximately 50% being transfered.
Do i reduce this over adjustment?
4. Is the 10% tw\tt weight too low? What advantage is there to add more front tt weight?
5. Does increasing the tw/tt ratio change all weights on frt/back axle tv? I assume rear axle would go up and front axle show slight drop, which should lower the high front weight.
