oxygen's avatar
oxygen
Explorer II
Jul 08, 2013
Help with scale numbers
Weighed at local grain elevator and here are the numbers
truck by itself
steer axle-3240lbs
drive axle-3000
gross weight-6240
tt + tv- WDH(equalizer) bars disconnected
steer axle- 2940
drive axle- 4200
trailer axle - 5360lbs.
gross weight- 12500
tt + tv-WDH engaged
steer axle- 3060
drive axle- 3900
trailer axle- 5540
gross weight- 12500
tv is Rockwood Ultra Lite, ship weight- 5676, hitch weight- 739
gvwr- 6739, this info taken from web site, yellow sticker on side of tv for dry weight is 5840lbs
tv iv 2012 f150 EB, screw, heavy duty, payload is 2440lbs.
please ?check my math
total gross weight mlnus truck gross, engaged = trailer weight = 5540lbs
tv engaged Wdh minus tv unhitched = 720lbs , weight transfered to tv
tt hitched axle weight minus tt unhitched axle weight = 180lbs.
720lbs. + 180lbs. = 9oolb tongue weight
tongue weight is 16% of tt weight
front axle tv unhitched minus hitched front axle = 300lbs.
engaging wdh put back 180lbs to steer axle
is tongue weight added to tt axle weight to get tt weight?
any adjustments needed?
any adjustments i should make to wdh?
  • How much front axle weight restoration does Ford recommend in your owner's manual? You are over the 50% that others have mentioned.
  • oxygen wrote:
    It seems to track well. once in awhile the front of tv seems light to me
    thanks
    It looks like if you can adjust the hitch, you can put back another 150 LBS on the front axle of the truck.
    thanks
    It looks like if you can adjust the hitch, you can put back another 100 LBS on the front axle of the truck.
  • It seems to track well. once in awhile the front of tv seems light to me
    thanks
  • "is tongue weight added to tt axle weight to get tt weight?"
    Yes it is included in the trailer total weight
  • 900 pounds looks right. How does it handle? Do you have any adjustment left? You can try tilting the head back and see if it rides better.
