Geeallan's avatar
Geeallan
Help with tow rating for 2011 Toyota tundra and new TT
Hello, we are looking at a 2015 heartland prowler 26p bhs. We have a 2011 Toyota tundra and we are confused if the GVWR of the double cab tundra will be overweight? Here are the numbers:
2011 Toyota tundra double cab 5.7 liter 4x4
GVWR 7100 lbs
Approx weight of truck is 6000 lbs
Towing capacity is 9300 lbs
Dry weight is 6246 lbs
GVWR 9000 lbs
Hitch weight is 760 lbs
We are concerned that the hitch weight is taking away from the GVWR of the tundra and will only allow for approx. 340 lbs in the tow vehicle (including persons in the vehicle). Are we doing our math right or should we look at other numbers? Thanks, we are so confused, we are used to towing a 1988 popup and want to graduate to TT towing! Thanks in advance.
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
