acritzer's avatar
acritzer
Explorer II
Apr 04, 2015
Hitch set up help
Hi everyone. Hoping for some clarification, guidance and ultimately some peace of mind on my hitch set up.
I've read the set up procedure but seem to be running into a few problems.
2011 Ford Expedition EL, 2008 Keystone Cougar 29BHS
I don't know the brand of the hitch, but it has round bars.
Questions:
1) When measuring the TT for levelness can you use the floor just inside the door, as you would when setting up to camp?
2) How important is it for the bars to be parallel to the frame and/or ground?
I need to go through the process again using a couple of different tactics, but from what I've been able to do I've gotten the TT level. However, in order to put a decent amount of tension on the bars and actually get some WD going the bars are angled up quite a bit. It seems as though I have to work really hard to get them latched up. Often times I'll just use the jack to hold the weight until I get the snapped up.
I'm also wondering what is "acceptable" for the back end to dip? My best efforts have gotten it to about 1" dip on the back and the front is up about 1/4". That being said though, I need to measure again before using the bars to compare the two. So far I'm only comparing the unhitched height.
Thanks for any help you have and please ask me questions. I know I'm not all that clear.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 30, 2025
