Am I likely to notice a big difference if I lower my tongue weight by 200lbs? The overall weight will be almost the same, slightly less. But the hitch weight will be 200 less. Thanks
What a trailer (or any sort of RV) is "supposed to" weigh per the published specs is almost as accurate as predicting the weather... for next year... the only thing you can count on is they are ALWAYS heavier than the spec. Yes sir, I said "always":
Not enough into. Yes, 200 pounds tongue weight difference is a big deal on a light truck. It's nothing on an F550.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
