joelyn's avatar
joelyn
HITCH WON'T RELEASE...UPDATE UPDATE..........
OK got back from a short trip and went to unhook the trailer and I cannot get the hitch to release from the ball. I have had problems with another trailer but after bouncing and kicking it it would eventually release. This time I greased the ball and under the hitch before hooking up, drove home and would not release for nothing. just had to pull the pin and drive the truck away to disconnect, but as u can see the hitch ball still will not come out.
The hitch is a EQUILIZER SWAY CONTROL BRAND, IF THAT HELPS. PICTURE IS A LITTLE DISTORTED, WILL TRY TO REPOST IF IT WOULD HELP FIND A SOLUTION.
WHATS MY PROBLEM if anyone knows??????
thanks
? Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
