Only_True_Mosno
Jun 04, 2014Explorer
Honda Generator Question
I have two 2000 Honda Generators with a parallel kit attached to one of them. I unfortunately do not have the companion but rather two standard 2000's. Here is my question that I can't seem to find the answer to...
When I am only using one of the Generators with my RV...can I plug the RV into the generator with the paralell kit attached that has the 30 amp recepticle or can the generator with the paralell kit attached only be used when the two are hooked together?
In other words is it better to use a 30 amp adapter on the generator without the kit attached...or is it okay to plug it into the one with the 30 amp kit attached?
Clear as mud? Thanks for any help!
