MetalGator's avatar
Mar 03, 2015
Hot water no longer works on electric
The water heater in my TT runs on both electric and propane. I usually always turn it on (electric) when we get setup so we always have hot water. One trip I noticed that the water was only warm (when hours before was hot). I went outside and opened the panel and noticed the "reset" button had popped out. I reset it and the hot water heater came back on. Sometimes it would run for over 24 hours, other times for only a hour or two. I started just using the propane mode when we needed hot water. On our last trip, I tried using the electric and now it won't work at all. Works fine on propane. Anyone have any idea what the problem could be?
  • Looks like high temp safety is bad. Easy repair and not too expensive. Just swap it out and you'll be ok. This is also a good time to check the anode Godin the tank the erode away and Need to be replaced periodically.
  • It doesn't hurt them to run both heat sources at the same time. They are unrelated and have no effect on each other.
    I would check the resistance of the element. If it's open then it's shot.
  • Bobbo's avatar
    Bobbo
    Explorer III
    My water heater is an Atwood, but I always have both gas and electric on at the same time while we are showering.
  • I have almost always run mine on both gas and electric at the same time for 7 years and no problem doing it. Those devices do fail.
  • BB_TX wrote:
    My first guess would be the high temp cutout has failed, especially since you have already had to reset it several times. Surburban? Easily replaced.
    Yes, I believe it is a Surburban. I know exactly when it started happening. One trip I forgot to turn on the water heater. Wife went to take a shower and there was no hot water. The owners manual said you could turn on the electric and the propane at the same time to get the water heater up to temp quicker. That's what I did and that's when the electric started acting up.
  • My first guess would be the high temp cutout has failed, especially since you have already had to reset it several times. Suburban? Easily replaced.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
