ljedik
Jan 04, 2014Explorer
enblethen wrote:
Bypass in off position should have no water or antifreeze in the water heater.
You did drain the water heater during winterizing?
I may have made an amateur mistake and put antifreeze in the HW tank. I know for sure that I did turn the bypass valves on though so the main lines shouldn't be leaking into the HW tank unless a valve has failed. I need to get inside and take a look at the situation.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
